Circuit tools only showing throttle channel for one run
Data Analysis Fundamentals
When comparing two different session/.vbo files I can see the chart has two lines red and blue in the delta, speed, and g channels. However the charts for throttle, rpm, and brake channels only show one line. I’m trying to get both lines to compare throttle application. The exported data has the information it will just not display both. I have to open two windows with each .vbo file and i can see the rpm and throttle for each individually. Thanks!
Are the channels named the same in both files? What software are you using for the analysis?
Hi Matthew, sorry for the slow reply on this.
It sounds a bit strange, possibly a bug? I'm happy to take a look at it for you if you send me through the two data/video files: [email protected]
