E36 M3 Dual Vanos S50B32
Hi Everyone,
I was wondering if anyone had a Motec base map for a S50B32 or dual vanos BMW? I'm also interested in camshaft setup parameters and what people have used.
Thanks!
Hi Tim,
Which ECU? M1 Tune has the base starting parameters for the S50 and these should be followed as they are specified in the help. Once these parameters are set, then the cams are setup in the standard manner.
Hi Stephen,
Ecu is M130 GPA, thanks we will look at those parameters for setup. Do you have any base or tuned camshaft aim tables for this model?
