Oil temp sensor
MoTeC M1 Software Tutorial
I have a resistance type oil temp sensor and cannot find the table under oil temp tab to set this up.I can only find the voltage translation table but no resistance table.How do I set this up?The company supplied me with a resistance sheet.
Calculate the voltage using the voltage divider equation.
Vout = VRef* (SensorResistance/(SensorResistance + PullupResistance))
MoTeC M1 ECUs have a 1000 ohm pullup resistor to the 5V Voltage Reference for the Temperature inputs.
Hi,
What sensor is it that you are using?
