Using PH injector terminals as low-side on an M150?
MoTeC M1 Software Tutorial
I am attempting to use Bosch 0280158038 injectors on a 12 cylinder engine. These injectors are listed in the injector dropdown list in M1. I have them wired to the peak and hold pins, as there aren't 12 low-side pins and it is my understanding that the PH pins can be configured for low-side? Is this correct? Is there any configuration needed to enable this?
Thank you in advance.
PH injector outputs are able to be used with peak hold and saturated drive injectors. The setup is built into the injector calibration with the drive type and target currents.
Hi Nathan,
Thanks for the response. Are you saying it should "just work" since the injector is listed in the presets dropdown?
Yes, correct.
