BC P share
Boost Control
hi,
the p values are set to extremes. And you advise against that. And d and I are very minimal. Surely, this will cause a lot of fluctuations?
Please have a look at the pictures.
Somehow, couldn’t attach the p share pics.
The table is somewhat like this:both axis are not defined. It’s it says p share (hp) and p share dynamic. Please elaborate how is proportional gain is different in dynamic.
When starting open loop trial, I should set all 3 p/d and I to zero? And tune the waste gate feed forward first? There is another wgdc table called wgdc spool.
