Boost valve
Boost Control
The boost solenoid valve i am using just has #1, #2 and #3 ports. I am able to blow through #1 and #3 so safe to assume that would be common and normally open then #3 would be normally closed?
attached are 2 different set ups one for internal and one for external wastegate control
hope this helps
Regards Ross
