How to wire a rotary switch Boost control
Boost Control
Hi I need a bit of help on how to wire and make a 12 position rotary switch For boost control it’s being installed on a Wolf V550 ECU
Thanks
Hi Simon, apologies I missed this post. I'll assume you've found your way through this by now but for others visiting the forum I'll reply anyway. A rotary switch just requires a 5V supply, sensor ground, and then a connection to an analogue voltage input on your ECU. From here this needs to be configured so that the ECU understands the relationship between the input voltage it's seeing and the switch position. Lastly you can then configure the switch position as an axis for the boost control functionality. I can't help specifically with the Wolf ECU as I haven't utilised one sorry.
