Innovate SCG-1 stuck at 43.8 psi
Boost Control
I figured I'd ask here, maybe someone can help.
My SCG-1 is stuck at 43.8 psi, can't seem to reset that out.
Tried A/F sensor reset without success. Also tried to order an USB to COM adaptor to tried and update firmware, no success there either (might be the adaptor, can seem to establish communication between Laptop and scg-1).
I getting a bit tired of that device, I bought it a year ago and between car being stored over winter and last race season, it worked as intended "maybe" 2-3 race weekend....
anyone can help?
Thanks!
I would be checking the sensor / sensor wiring. If you disconnect the sensor does the reading change?
Problem seem's to be solved.
I contacted innovate and, even if out of warranty a bit, they sent me a new pressure sensor. Received it yesterday, installed it right away and so far (couldn't test drive the car) everything seem's to be normal.
