Link ECU boost control
Boost Control
Relevant Module: Getting Started > The Ten Step Process
Hello, i bought the boost control advance course. Will you make an example with Link Ecu? Thanks :)
There are some older webinars covering Boost Control on the Link G4+ ECU. Check out these:
https://www.hpacademy.com/previous-webinars/070-electronic-boost-control-link-g4-ecu/
https://www.hpacademy.com/previous-webinars/131-tuning-open-loop-boost-control-link-g4/
Not specifically about boost control, but it talks about using that on the dyno tuning...
https://www.hpacademy.com/previous-webinars/133-how-to-tune-a-turbo-engine/
Hi, did the same and was looking for exampels with the Maxxecu. Do you have that?
Thanks 😊
