Worked examples
Boost Control
Will worked examples be added for other ecus? ie Link G4 Plus.
The course was extremely helpful till the Motec worked examples.
Yes we're intending to add other worked examples. The reason we haven't added a worked example on the G4+ is that the closed loop boost control on the G4+ currently is problematic. We've done some testing and worked with Link and I believe they are close to releasing a rewrite of their boost control system in light of what we found.
For now on the G4+ platform I'd strongly advise to set the boost control up using the passive open loop system as described in the course. This is how I set the boost control up on my own G4+ applications.
Thank you Andre
