feedback
Brake System Design and Optimization
Relevant Module: Fundamentals > Brake System Hydraulics
Is there a way to turn on autoplay between modules? Having to constantly click play every 5 minutes gets tiresome, I would prefer to be able to just watch it all from beginning to end. I do have the autoplay button selected below the screen but it doesn't play the next video as one would think. I tried cycling it. Just thought you would like to know. Thank you.
It might help if you supplied the device/platform you're using, the OS, and the app'/program?
Depending what you're using, you may be able to make a play-list where they will automatically play in sequence.
I haven't come across this issue, but I'd say it's a browser plugin that's causing this.
Try it in an incognito tab and see if the same behaviour occurs when you have a tick and let us know how you get on.
Also as Gord mentioned let me know what browser and device you are using if the incognito tab still gives you the same trouble. If it doesn't it will be a process of elimination to find the plugin that is causing you grief with this.
Note that between modules, it will drop out of fullscreen. That is something we can't currently change as it's a Vimeo issue, but we have a long-term plan to solve that annoyance and add some extra features that we currently can't with Vimeo.
You can reply here or email support@hpacademy.com regarding your incognito tab testing result.
