First Turbo Project
Build Threads
I am building my first turbo project it is a 1968 C20 on a 1972 C10 chassis. I am going to challenge myself to build as much as I can for this project. I plan on running a Haltech ECU with the IQ3 dash. I want to run a twin turbo but not 100 percent sure yet. I have an LQ4 with a T56 behind it. Plan is to build full turbo system on the stock motor to get the truck up and running then build a nice motor to swap out.
I will try and keep this post updated.
Very nice! Definitely keep this thread up to date with your progress as it looks to be a good one
Looks like a great project, it does give a great deal of pleasure doing project from start to finish with little help from 3rd parties , and it forces you to learn what is out of your comfort zone , hope you keep us all posted dwayne newzealand.
I fabricated the transmission crossmember yesterday and was able to get it installed today. Don't mind the long bolts its all I had laying around the shop today. Also got the rear frame rails welded up and ready to install...
Making progress. Hope to be done by end of August.
Got some work done this weekend. Removed the original rear section of the frame and added in my new frame rails. Going to finish welding this week and then make the trailing arms. Once I am done with the rear I will put the cab back on and start with the engine compartment.
