Lightweight, universal alternator.
Build Threads
Hi all. I am building an SCCA E-production 240z race car. I am rubbing the OEM L24 motor modified to class rules, as required. I have heard everyone from Jay Leno to YouTube builders reference “lightweight” universal alternators.
Does anyone have suggestions for make/model of such alternators? I don’t need more than 20-30A to keep the battery from draining during a race and rad fan use in the paddock. I can handle the fabrication necessary to mount the unit, so just looking for the product details itself.
thanks in advance!
  • trim.536B71C1-E9CD-4D58-B5FB-8BD988BC4A46.MOV
I have used Powermaster 8168 alternator (based on the 93mm Denso alternator), as well as the similar RaceProven models.
http://www.powermastermotorsports.com/race_alternators.html
Most aftermarket options seem to be based on the Denso David is suggesting, and a 50A won't draw more power from the engine than a 30 or 40A - and will have the benefit of having a reserve in case you need to drive more slowly - yellow flag, etc.
I have seen a very small alternator on a small/mini excavators, with an output of 22A, IIRC, if You REALLY want to minimise the size - it's been a long time, so can't recall exact details.
Thank you!! I will look into the Denso and make a purchase
