My MKIII supra thread
Build Threads
HinAll,
Havent post much in these forums but i am in the middle of a rewire of electrical and engine
Went through the wiring course-club level so following suit.
Here is my mock harness. It is about 90% done.
I have not added the fuel pressure/fuel temp as that will be ged from an injector dynamics F750 fuel filter.
Also not added is the oil pressure and oil temp.
I have a general ideal on cam sync but debating on a couple of possible options
I have put both the dash and the ems in the same harness but i feel if i seperate rhem it will be better and allow for future expansion.
The motor picture was the old oem wiring which was hacked.
Looks good Wayne!
Looking forward to seeing more of this as you work through it.
I have seen you have not added some of these sensors. We will usually still run the wiring or at least some spare input, 5v, ground,12v wires so things can be added later without having to change the loom again.
Great to see another MK3 build on here!
would love to compare builds with yours as we go along.
Also may have a few questions for you on little tricks and ideas you have.
