1000BHP+++ Front Wheel Drive Drag car - Its Fast, Its Pink and it needs your name on the side! UK
Buy Sell and Swap
A place to buy, sell and swap HPA course-relevant equipment and supplies. Tuning widgets, wiring apparatus, engine building gizmos, fabrication gear, alignment thingamajigs and more welcome.
Where to start on the HoK Neon Pink beast!
FRONT SHOT - CLICK HERE
Pictures to be updated if interest follows, I will also do a walkaround Video -
This Car weighs 780kg as it stands which must be up there with the lightest of the FWD drag cars out there, The Tigra shape is also fairly slippery which makes a huge difference when close to 200mph...
The car is a Mk1 Vauxhall Tigra that was owned by our lead Fabricator Dan for many years and was developed into the car you see here today. The amount of blood sweat and tears to get it to where it is now was unbelievable but as with every project something usually stops them from being finished, the tuning being the case for this project and being TDi specialists, we don't have the time to take the car further than it is now.
The Car was built solely for drag racing with the hope to be the Quickest and Fastest FWD Drag Car in Europe with the hope of upsetting some of the guys in America too! The Plan was Sub 800kg and over 1000hp...
The main part of this whole build is the 20XE Engine (note there is no ‘C’ stamped on this engine, this is due to the block being the earliest possible pre Cat block due to the core shift found on later engines)
5 Blocks were chosen, all of them X-Rayed to find the one with the thickest walls, with the best chosen it was bored to accept UK Made Ductile Iron sleeves and ½” head studs. The ½” Girdle and Billet main caps line bored to accept the custom made Australian Crankshaft. JE Pistons custom made a set of 9:1 HD forged pistons and ZRP I-Beam rods were sourced along will the best quality bearings and ARP hardware. You will NOT get a stronger XE bottom end than this.
The head was built using a Brand New late spec casting and oversize valves from Paul Ivey with the full tried and tested Kent Cams valvetrain and custom grind cams to suit 9000rpm+. The ports are huge and many heads were cut to know where the gains could safely be made. It was a number of years ago when the head was flow tested but the numbers were well above the Honda’s of the time.
The rest of the engine components were taken from the top shelf with no expense spared and fabrication work, all done by Dan himself, is first class. If you look at the spec list I’m sure you will agree.
The Shell has had extensive modifications, 100's of hours removing unnecessary material and seam welding were done as well as an MSA spec roll cage. The front end is fully spec framed to allow easy access to all of the drivetrain.
Anything that could be Fibreglass was moulded including the full 1 piece front clamshell, Doors, Tailgate ect. The Roof is a single skin of Carbon Fibre and the windscreen 4mm Polycarbonate, still with the protective covering!
An SQS 4 speed 4Degree Dog engagement gearset is installed in the M32 housing along with a Quaife ATB Differential and Custom indestructible driveshafts. The SQS Sequential shifter finished things off. The gearing on this car will allow 190mph in top gear when allowing for tyre growth which will easily be enough when combined with a 1.3s 60ft to be the Quickest and fastest FWD car in Europe. The car was always built for 8s at over 180mph.
The car has custom made 15” Banded steels fitted with 26” x 10” MT ET Drag slicks
The rear are ‘Front Runner’ Lenso 15x3.5” fitted with 26 x 4.5” MH Drag tyres
As can be seen in the picture the dyno wheels are also included fitted with Nitto N555r Tyres
Too many chassis mods are there to be listed so hopefully the pictures show what is required. The Brakes are substantial Willwood 4 pot drag spec but a Parachute is included. There are also Wheelie bars supplied.
The car is running a Motec M130 ECU which at the moment was configured by Dave Rowe at EPS Motorsport to start and idle. We have a Race Grade 8 EGT to CAN Interface and LSU 4.9 to CAN interfaces installed.
Previously the car ran on a Syvecs ECU and at 2 bar of boost produced almost 800hp before the project was shelved due to other projects, one of which was an 800hp Evo 8 that the Syvecs ECU was utilised for.
Wiring Diagrams and user manuals for everything we have will be supplied.
I’m sure LOTS of stuff has been missed from the description and spec list but rest assured no corners were cut building this car and the minimum of work is required to make this race ready.
This car is perfectly aimed at the tuner looking to make a name for themselves quickly without the need to for the 4 or 5 years required to build a car to this specification, we estimate that well over £40000 has been spent on parts alone and the build cost for a car like this could easily creep up to £80,000+
We would love to sell the car in one hit to a fellow enthusiast who will take the time to develop the car at the track, within a few test days this car will easily produce the required numbers and be a perfect advert for anyone choosing to put their came on the side
The price is £25,000 and is a bargain at that. Please no dreamers or silly questions.
Car is Located in Yorkshire, UK. Delivery can be arranged. We will only consider selling the engine Whole if no interest in the car complete. Once the engine sells the rest of the parts could be listed. Anyone wanting parts should send a reasonable offer on their first contact to peak our interest in breaking the car.
Spec Sheet -
20XE Engine
Fully Built Engine (Custom Billet Crank, I beam Rods, Sleeved block)
Forged 9:1 87mm (1mm oversize) JE ASV Pistons with HD Pins and rings
1/2" ARP Head studs. ARP Mains Studs Expert Racing Mains caps and 1/2" Girdle
Custom Ported Head with +2mm Bigger Valves from G&S / Paul Ivey
Kent Custom Inlet Cam - 11.9mm Lift / 278 Degrees
Piper Custom Exhaust Cam - 11.9mm Lift / 286 Degrees
Vernier Pulleys
BorgWarner S400 Turbo with Billet 80mm Inducer 112mm exducer Comp Wheel
2 x 44mm Tial Wastegates - 1.3BAR SPRINGS
1.5" 316l Stainless Tubular manifold & 4" Exhaust
Garrett 1000HP Core Water to Air Chargecooler
Davies Craig water pump to Ice cooler box with Aeroquip hoses
Custom Inlet with Bosch Motorsport 80mm Throttle body
WON 250 Nitrous system - Direct port
Castrol 10w60 oil
QED Dry Sump With AH Motorsport tank in car
Helix 7.25" Twin Plate Clutch
SQS 4deg 4 Speed drag Dog engagement gear kit
Quaife Differential
26 x 10 x 15 MT ET Drag Front Tyres
4.5 x 26 x 15 MH Front runner Rear Skinnies
Wilwood Dynalite 4 pot Drag brake kit - 140-8442-D
Hayabusa 6 pot rear brakes mounted to custom Alloy hub axle
Wilwood Pedal Box
Corsa EPAS Steering motor
Kirkey Bucket Seat + Sabelt 4 Point Harness
Motec M130 ECU
Aeromotive Eliminator 1400 Pump
8 x ID1700 Injectors 14mm
-12 and -10 Aeroquip Fuel hoses
M&W Pro-Drag4 4 Channel 250mJ CDI
MSD Coils
Iridium Spark Plugs
Race Grade RG-TC8 EGT to CAN interface
https://www.darksidedevelopments.co.uk/products/1000bhp-vauxhall-tigra-drag-car-project.html
Car is being split -
Motec M130 ECU with Group R Package & Level 2 Logging Upgrade - £2000Motec Lambda LTC Single Bosch 4.9 - £240M&W Pro-Drag4 4 Channel 250mJ CDI - £750MSD Mustang Coils with Iridium Spark Plugs - £SOLDRace Grade RG-TC8 EGT to CAN interface with AEM Sensors & Autosport connectors - £500Race Technology Dash 2 - £300Cartek Battery Isolator - £150
Engine Complete w Sump etc or will split: - £7000
20XE Engine - £4000Fully Built Engine (Custom Billet Crank, I-Beam Rods, Sleeved block)Forged 9:1 87mm (1mm oversize) JE ASV Pistons with HD Pins and rings1/2" ARP Head studs. ARP Mains Studs Expert Racing Mains caps and 1/2" Girdle
Custom Ported Head with +2mm Bigger Valves from G&S / Paul Ivey - £1900Kent Custom Inlet Cam - 11.9mm Lift / 278 DegreesPiper Custom Exhaust Cam - 11.9mm Lift / 286 DegreesVernier PulleysQED Dry Sump Kit with AH Motorsport tank - £1600
T4 Twinscroll Tubular Manifold w Billet Collector 1.5" 316L & 4" Exhaust with 40mm Screamer pipes - £1000Garrett 1000HP Core Water to Air Chargecooler - £500Davies Craig Water Pump to Ice cooler box with Aeroquip hoses - £150Custom Inlet with 2 Fuel Rails and brackets - £SOLDBosch Motorsport 82mm Throttle body - 0 280 750 101 / 0280750101 - £225
M32 Gearbox with SQS 4deg 4 Speed Drag Dog engagement gear kit & Quaife Differential - £2900Custom Driveshafts and upgraded CVs - £600SQS Sequential shifter with Electronic assist, Indicator Display and Racing cables - £1250Helix 7.25" Twin Plate Clutch with custom 8 bolt Flywheel - £800Ratios:1st - 30 x 10 = 3.0002nd - 26 x 13 = 2.0003rd - 30 x 22 = 1.3644th - 26 x 26 = 1.000Final Drive 67 x 17 = 3.941
Wilwood Dynalite 4 Pot Drag Brake Kit - 140-8442-D Bolt on modified - £700Custom Alloy Hub Rear Axle with Hayabusa 6 Pot Rear Brakes & Shocks - £400Wilwood Pedal Box with Wilwood Master Cylinders & DBW Sensor - £500Hydraulic Handbrake with AP Racing Cylinder - £150
Corsa EPAS Steering motor & controller - boss and column - £100Shell with Front Struts, Wheelie bars and panels. radiator and fuel tank - £2000Parachute Setup - £SOLD
26 x 10 x 15 MT ET Drag Front Tyres - £SOLD15” Steels Banded to 10” wide - £SOLD4.5 x 26 x 15 MH Front runner Rear Skinnies - £SOLDLenso XPD 15x3.5 Skinny Rear wheels - £SOLD
