F.S. Fuelabs 92902 In tank pump 190GPH
Buy Sell and Swap
A place to buy, sell and swap HPA course-relevant equipment and supplies. Tuning widgets, wiring apparatus, engine building gizmos, fabrication gear, alignment thingamajigs and more welcome.
I have several Fuelabs 92902 fuel pumps. Pump is rated for 190GPH @ 43.5PSI. E85 compliant. PWM speed controllable. I purchased these when it was the largest unit on the market and was running several in one tank. ALL of the units have been factory sealed and certified and have reports to verify.
$500 USD for a single and $450 USD if you purchase 2 or more. Includes flat rate shipping in the lower 48. Each unit was slightly modified to fit in the tank but does not effect the operation of the pump. I do have a few of the install rings and other assorted filter hardware. Ill include that as part of the first few units that go.
https://www.fuelab.com/92902-fuelab-1800hp-in-tank-power-module/p292
