Motec M800 and M400 FS
Buy Sell and Swap
A place to buy, sell and swap HPA course-relevant equipment and supplies. Tuning widgets, wiring apparatus, engine building gizmos, fabrication gear, alignment thingamajigs and more welcome.
I have a motec m400 and M800 for sale. I can send more pictures if requested. Here is a list of unlocks for each of the ECU’s
M400: M400 Enable, Gear Ignition Cut, Hi/Lo Injection, Lambda Single, Logging 512K, Overrun Boost, Traction Control. - $3000
M800: M800 Enable, Gear Ignition Cut, Hi/Lo Injection, Lambda Dual, Logging 4M, Overrun Boost, Traction Control. - $3500
Hi Isaac,
What are the serial numbers for the ECU's?
MoTeC Serial Numbers:
M400: 16910
M800: 24875
M400 # 16910
Options
24110:ENABLE
24105:ADVFUNC
24101:512K LOGGING
24102:SINGLE LAMBDA
M800 # 24875
Options
28110:ENABLE
28105:ADV FUNC
28101:1M LOGGING
28108:4M LOGGING
28102:SINGLE LAMBDA
28103:DUAL LAMBDA
