A place to buy, sell and swap HPA course-relevant equipment and supplies. Tuning widgets, wiring apparatus, engine building gizmos, fabrication gear, alignment thingamajigs and more welcome.
If anybody is interested -
"These are EIGHT custom made forged pistons originally designed for a Nissan VQ30.
They are for a standard 93mm bore. A distorted bore meant I couldn't use them and had to buy ANOTHER set at 93.5mm....at a cost of well over 1000 UK Pounds. Hey ho.
They come with pins and rings but no locks.
The exhaust valve cutout hasn't been applied, allowing the correct diameter and depth for your valve, lift and compression ratio to be machined.
Would be good for a compression ratio of 12:1 or more on a standard thickness gasket."
Would like them to go to a good home, so more than happy to pull them off FleaBay.
You might want to check your listing link, it takes me to my selling page
Thanks...I hate eBay...try this -
Works for me
Thanks for checking
Text
