dynamic compresion
Variable Cam Control Tuning
to what degree does intake valve close effect CR?
hello it doesn't affect compression ratio much if any as the compression ratio is a calculation of bore stroke and head gasket thickness and combustion chamber, it does affect the cylinder pressure though, which is a totally different thing
Regards Ross
