HONDATA S300 , i cannot edit high cam tables
Variable Cam Control Tuning
Hi
using S300 for the first time , so i mapped up the low cam and started into the high cam , I had to leave it for a while , when i went back , anything i did , would not alter the a/f ratio , i went back tot he low cam and could alter no problem , but nothing in the high cam , i must have locked it somehow , now i loaded another calibration and could edit that in either high or low , fair enough i can start again , but if i run into this again , i will need a solution , its not the secondary tables ,
any ideas ,
Cheers
Hopefully you've resolved this by now, but comparing the functioning file to the non functioning one will hopefully help you discover the difference.
Perhaps VTEC is not being activated, so the table is not tunable?
If you really get stuck, you could copy your work thus far into a tune file that's working for you.
