video blurry
Variable Cam Control Tuning
Relevant Module: Practical Skills > ECU Configuration
Hello HP team..Thanks for your info on all of this because i am beginner..you are my only help. I want to ask a question. Why the videos i watch become blurry? it is impossible to watch them because you get dizzy.
Hello, Michail - it would help if you stated which video(s) you're having the problem with, the device you're watching on, the OS (operating system) version, and the program/ap' you're using?
In the meantime, check the resolution hasn't been accidentally changed, and that you're correctly logged in, if applicable.
thenks man i found the problem..the problem was in the resolution..thenks!!
