can bus
CAN Bus Communications Decoded
Relevant Module: Practical Discussion > Splicing Together New CANBus Wires
can we use shielded wire for can bus on motec m150
yes you can. The shielding isn't usually required, it's more important that the CAN Hi and CAN Lo wires are twisted with each other. Usually 1 twist per inch is sufficient.
