MAXXECU Sport to Motec C127 display via CAN OBD2
CAN Bus Communications Decoded
I've setup MAXXECU to send display data to an OBD2 data. Are there specific settings other than choosing CAN OBD2 OUT MaxxECU Sport?
Also can anyone send me DBC file for setup C127 Dash, It's work now with, RPM, MAP, TPS, VOLT, ENG TEMP, IAT
Ineed A lambda, IJPU, IGN TIMING, .... reading and another sensor on the Maxxecu
Here is the Standard MaxxECU CAN protocol. I got it from the MaxxECU website, start with this page:
https://www.maxxecu.com/webhelp/can-default_maxxecu_protocol.html
Thanks
