MINILINK and AEM CD5
CANBus Communications Decoded
Hi! I'm running a g4x and a AEM cd5 display its already setup with the predefined channels. I will like to see ''AFR TARGET" and ''ethanol %'' but cant find a way to add them. Is it even possible? I also ran out of inputs on my g4x, can i get an aem 22 can channel module to stream to the cd5 and from there to the g4x? Can i set one of the two push buttons of the cd5 as an input on the g4x?
Yes you can do these things.
You can create messages to send additional items in both directions. Have you completed the course yet?
