Ends in 6 hours
hey
can the motec c127 dash work with syvecs ecu ?
Since the S7+ has a CAN bus output then it can surely be connected. I have worked with various LifeRacing ECUs with both CAN and Serial connections, and I understand the Syvecs shares hardware and some underlying software architecture with that.
Hey
Thanks for the replay
I pair Haltech dash with Link ecu the dash didn't work like when I pair it with Haltech elite 2500 ecu.
Motec or syvecs has this problem?
There has been an update to the Link Firmware to work better with the Haltech dash I believe. Check out the Link Forum for these threads about haltech dashes:
The main issue that I have had getting a MoTeC Dash to work with the Syvecs ECU's is that there didn't seem to be a standard CAN Message set out of any of the Syvecs units that I have worked with, each has required having a custom CAN receive template made for them to get them to work. Once this is done, there are no issues.
thanks a lot of the help
Text
