Need help with setting up a logcfg.txt file with Tactrix Openport 2.0
Data Analysis Fundamentals
Hi all,
I recently picked up an Openport tactrix 2.0 and I am trying to figure out how to set up the correct "logcfg.txt" file to use for standalone data logging on my Subaru. I was able to successfully get the sample file for K log that comes with the ECUflash software to work, however I do not know how to modify that to set up the parameters that I want to data log while driving ( without using a laptop.) Does anyone have a list of definitions/ text file already set up for logging with the SD card?
Thanks for the help!
Alicia,
Standalone logging involves manually scaling monitors, identifying locations so it's an advanced function and in order to get you going more quickly, it may be worth a little time at the link below to find someone else's sample file for a similar year/model.
http://forums.openecu.org/viewforum.php?f=57
