Prior knowledge for data analysis
Data Analysis Fundamentals
What background knowledge I need if I were to take data analysis course? I'm concerned with setting up the loggers. Do I need to be proficient in CAN bus in order to configure the data logging equipment?
Hi Hairul,
No previous knowledge is required, anyone can take this course. You will find that many loggers already provide the CAN templates that are preconfigured to work with different cars so in many cases you don't need any CAN knowledge. If something comes up while you're setting up a logger, I'm sure we can point you in the right direction to find a solution, that's what this forum is for!
Tim
