Boost control
Diesel Tuning Fundamentals
Tell me, that is the boost map is intended to adjust the limit and so that the failure of the excess boost is not ignited. From this it follows that first I adjust the fuel-air mixture, increase the supply and pressure of the fuel, then monitor the resulting boost pressure and correct the map, right?
