[2JZGE SupraMk4 EmuBlack]Recommended route for hose and wiring from intake manifold to car interior
EFI Tuning Fundamentals
I purchased EmuBlack.It has a 4barMAP sensor, but the SupraMk4 ECU is placed inside the car.Do you have any recommendations for a route to install a hose from the intake manifold to the inside of the car?
I suggest using a MAP sensor right next to the manifold to avoid pulses being excessively damped and transients delayed.
If you proceed with your plan, I suggest using thick firm silicone hose and making the routing as short as possible. Reducing the total air volume with 3mm hose can help some.
