80s OE sensors with Motec M150
EFI Tuning Fundamentals
Hi all,
I'd like to retain some of the original sensors on my EFI/ITB converted 1983 Ferrari 512 BBi. One of which is the original vehicle speed sensor that feeds the speedometer (pic attached). Are there any suggestions on how to get this OE sensor to work with the M150? Ideally, I'd split the signal to the dash and the ECU. However, I wouldn't be opposed to sending solely to the ECU, then sending a new calibrated signal to the dash from the ECU.
Thanks in advance,
Robert
If it's a 2 wire sensor used for speed sensing then I would guess it's just a variable reluctor sensor.
If that is the case you should be able to wire it to UDIG input and sensor 0v.
The polarity will just define the signal waveform whether it rises or falls as the tooth passes.
Oh, good point. I actually use a UDIG with the OE distributor reluctance sensor. I'll try that.
What about something like an old oil pressure or oil temp sensor? Would AV and/or AT inputs work for those?
Tentatively yes, there most likely will not be a calibration for them so you would need to have that done. Some of the older single wire sensors are not recommended for use as they are very inconsistent in their behavior as they rely on the engine grounds to complete the circuit back to the ECU, so they can get noise and other errors induced from this.
