Choosing the correct afr
EFI Tuning Fundamentals
What is the afr at 1.0lamda please?
I'm responding here mostly to verify my own understanding of this.
Lambda 1.0 is a representation of stoichiometric afr. That is the ratio at which the oxygen in the air is perfectly matched to the fuel to
Completely burn all of the fuel/air mixture. It is therefore dependent on the specific fuel in question.
Assuming pump gas. Stoichiometric mixture = 14.7:1 = lambda 1.0
Jguysr you're bang on.
Nick, as Jguysr said it is fuel specific. Here are some common fuel AFR/Lambda Stoichiometeric ratios
Pump gas 14.7:1 = lambda 1
Ethanol 9:1 = lambda 1
E85 9.75:1= lambda 1
Methanol 6.42:1 = lambda 1
Diesel 14.6:1= lambda 1
This does also depending on how you're reading lambda 1. Most wideband controllers will not know what fuel you're running on and will assume its pump gas so lambda 1 will always relate to 14.7:1 . For example if you had e85 and had it at lambda 1 the wideband would say 14:7/1:00 but the engine would actually be 9.75:1. Hope that doesn't confuse you :)
As Chris has in his post, different fuels have different stoichiometeric AFR values, however the Lambda stoichiometeric value will stay at 1, this is why I prefer to operate in Lambda rather than AFR, as it is a fairly fuel agnostic value, and can't be misleading if the sensor is incorrectly configured.
