distributor to coilpack conversion
EFI Tuning Fundamentals
Hi good day, I need some help to set up a AEM EPM on a 1993 suzuki swift gti turbo running a haltechP1000
It is pretty easy to drive coils from the Haltech, but what coil setup are you intending on running.
Individual smart coils , 2 wire coils with a driver or waste spark setup.
People need to know what hardware you are using before they can advise you on the software.
If you use a smart ( 3 wire coil ) you need to wire an ignition power and an earth, then the 3rd wire is driven direct from your ECU
