Dorito juice
EFI Tuning Fundamentals
Relevant Module: Fundamental Engine Principles > Air Fuel Ratio > Brake Specific Fuel Consumption
What would the range of BSFC be on a turbo rotary?
13 and 20b if possible
Thanks
Can't directly comment, as I've only a passing knowledge of them, but don't expect it to be very good because of the inefficiencies of the engine design, even if correctly tuned. You may be looking at 0.5 lbs/hp/hr, or higher.
I wouldn't worry too much about it, unless you're looking at what injectors to get, pump flow rates, etc. and need a rough size estimate?
