Injector Sizing
EFI Tuning Fundamentals
Good Afternoon all,
I wrote a small piece of software that uses the formulas learned in the EFI Tuning Fundamentals Course for sizing injectors.
I wanted to double check the results
For a 400 hp target with a V6 using 6 injectors and N/A my required cc/min is 398. Would that be correct?
Best,
Tom
That's in the ball park.
Excellent! Thank you for the quick response Dave. I find the software saves some time when running the calculations.
I actually used an app on my phone (there are several web calculators as well) to check your numbers...
That's about the number I got from all the calculators I used when sizing my injectors.
Great! Thank you for your reply.
I will be releasing a beta of the calc software in a few weeks if you want a copy to play around with.
Best,
Tom
