Not relavent
EFI Tuning Fundamentals
Hey just had an idea for the guys... what if they made a calculator or slide that has all these mathematical formulas built in.... either an electrical calculator or something like I've used in aviation, where it's a multi-slide calculator. As a newbie, trying to memorize all these calculations is ridiculous. Someone needs to at least create a reference guide that not only shows the calculations, shortcuts, etc. but also explains when you would need to use the calculation. Sorry, I'm an entrepreneur first and foremost, so I cannot stop the ideas. I'd buy one of those right now.
Ah, like the old slap-stick (slide rule) - I understand in aviation there are tools for air density, lift, etc, but similar tools may be less relevant for modern 'tuners' as it's part of the tuning software they'd be using, anyway.
I seem to recall something similar back in the carby days for jetting, using the air pressure, temperature and humidity measurements for oxygen content?
Yeah, like i just finished the Understanding AFR course and in it he refers to the AFR table and basic starting points. If that were on a laminated card that would be a cool product for them to sell at the end of the course... $10 who wouldn't want it?
As far as the old slide rule... ok, maybe just a cheat sheet with all those calcs on it with use cases and definitions?
As a newbie and a seasoned entrepreneur, it is throwing money down the drain not to offer these conveniences. People forget when they know stuff so well, they think everyone else knows it that well too. So they don't see the value. I'm telling you, it would be valuable to me.
