Stand alone knock sensor
EFI Tuning Fundamentals
Knock sensor is a must for every engine ignition tuning map. Unfortunately some time there are engines, like my 2022 Yamaha MT-09 that are not equipped with knock sensor.
My question is: Is there any reliable manufacturer that can offer a stand alone kit that may work with tuning software?
For example I am thinking of buying the Australian Woolich Racing software and hardware to flash my Bike ECU
Typically a tuner would be using an audio based device if the engine is knock limited, some examples; Plex knock monitor, Link KnockBloock, The Knock Box, Tuner Nerd, Phormula.
However, there is a reason most sportbikes don't have a knock sensor - the primary drive, spur gear transmission, and a multi-plate clutch all sitting in the common crankcase make so much mechanical noise that knock detection is near impossible - even with a good knock system attached to an experienced human ear.
Thank you for the information.
I understand that I need to be careful with the ignition map.
