VE table torque related?
EFI Tuning Fundamentals
Hi! Every time i watch MAP*RPM tables at specific RPM it remindes me a torque curve graph. Does real torque graph matches to MAP*RPM table?
They usually will resemble the torque curve of the engine, it can be a good check in that if the VE table shape and the torque curve are similar, then the tune is okay, if there are big difference then further investigation is needed.
