Anyone use Cadonix Arcadia Harness Express?
EFI Wiring Fundamentals
I've come across Cadonix Arcadia Harness Express and wondered if anyone had used it and had any feedback? It looks more complete and advanced than RapidHarness, with similar pricing. Unfortunately they don't offer demos of the Express version, so wanted some first-hand experience.
I´m using rapid harness. And I´m happy with it.
That subscription deal must be fairly new as I talked to them at the end of last year and it was about 3000USD/year then. It looks like they are trying to be more competitive at least.
We are using rapidharness at the moment but it definitely leaves a lot to be desired. Way too expensive for the functionality you get in my opinion. Not very flexible.
I think the "100 wire" limitation on the Arcadia express would be a problem. Even a basic 4cyl engine loom typically has more than 100 wires. It adds up quickly when you count all the wires to splices etc. For instance if you have 4 x 4 pin ignition coils, and you splice the power and ground wires to a single supply/ground, that would be a wire count of a least 18 just for the coils.
Yes, maybe Rapid Harness is a bit limited, but I´m getting free from my University Motorsport Team, so in that case is better than nothing.
Good point Adam, I’d not noticed the wire limit. That will be far too restrictive.
Someone on Facebook mentioned Zuken E3 that also has a similarly priced monthly subscription model, and looks quite feature rich.
There is also EPLAN software. But is seems that only works with a 3D model. Have someone used it?
