Audi Lambda sensor depinning
EFI Wiring Fundamentals
hello guys, I’m in the process of rearranging my engine wiring loom for my Audi B5 S4 and I’ve hit a stumbling block, I’m rerouting the off side lambda sensor but the wiring leading to the connector is tangled in the main loom so I’m looking at depinning it to get it where I need it to be, any ideas on how to depin this connector? Thanks in advance
I think that is a micro timer. So you need a micro timer extraction tool. The TE ones are pricey but you could try something like this:
http://s.aliexpress.com/I3ueYnQb
Cheers Adam, I’ll put an order in, I did have a terminal tool somewhere but I can’t find it for the life of me. There’s no locking tab hidden clip that I should be looking for? I’ve taken the spacer and orange weather seal out but can’t find anything in or around the connector to suggest it’s locked in with anything other than the terminal pins
Some of them have a purple lock that slides out the side, it is obvious however if it does. So sounds like it is just the terminal barbs holding yours.
