Cam Position/Home Wiring
EFI Wiring Fundamentals
not sure if I'm posting in the correct place, but I'm wiring a haltech elite 2500 on my audi s4 with a 2.7t v6. I'm confused as to how to wire the cam sensors for each bank of cylinders. The nsp software only has an output for one sensor.
Looks to me like you should use the SPI inputs for your additional cams. I think you have to use user-defined inputs using the SPI inputs (and user defined outputs if independently controlled).
