Connecting sheilded wire
EFI Wiring Fundamentals
Hi i am having problems trying to separate the sheilded part of my 2 core cable so that i can ground the sheilded part to rhe Ecu. Its raychem wire i am using similar to the picture attached is this the correct stuff to use? Thanks
Start with a pointy tool (small screwdriver or awl) on the cut end of the braid. Use it like a comb to un-ravel the braid. Just do a small 2-4mm section at a time. work your way around and down to the bottom. In just a few seconds, you will have a bunch of loose shield wires you can twist together.
Thats great thank you very much david.
Ahhhh thats how you do it. Nice tip
