Earthing engine block
EFI Wiring Fundamentals
Hi just have a quick question on earthing ? With the battery relocated to the boot of a vehicle Is it best to run a dedicated earth cable from the battery to the block ? or is it okay to run the earth from the block to the chassis and repeat this on the battery
its ok to run a cable to the chassis then chassis and cable from the chassis to the engine
just make sure it is appropriate sizes and bolts and chassis
