Ecu Master Emu Black 2jz ge vvti
EFI Wiring Fundamentals
Hi Everyone,
I have made a parallel harness for 2003 IS300 2jz Ge vvti.
Everything else seems to tick when checking outputs except the VVTI Solenoid.
Can someone please shed some light if i need flyback diode to get the vvti solenoid working ?
Current parameters i have got for the vvti are attached below.
Any help to point me to right direction will be appreciated.
kind regards
Sam
have you confirmed that the VVTi solenoid has 12v? and the OE ECU isn't still connected to the circuit?
