Emtron Ecu Hall Effect pinouts
EFI Wiring Fundamentals
Hey Guys,
let me know if there is already a topic on this or similar that i can relate too.
below is the pinouts for my Emtron ECU and im going to run a GT101 hall effect sensor.
this has a
wire 1: Supply +8v-12v
wire 2: output signal (grounded when a tooth comes past)
wire 3: Ground (just a ground)
so on this pin out do i wire it so the 8V supply is wire 1
wire 2 output signal to the crank -
wire 3 to sensor or 0v ground on another plug?
cheers any help would be appreciated.
Wire 1 - 8V (Emtron D3)
Wire 2 - Signal (Emtron D4)
Wire 3 - Ground (Emtron D5)
Thanks for your help. Would a VR just be wired to the crank index +\- pins respectively?
Yes.
