Harness Mounting - Loctite 330
EFI Wiring Fundamentals
I recently saw a video where Andre talked about harness mounting using aluminium cable tie hoops fastened to the engine or chassis using Loctite 330. I cannot seem to find anyone who sells the kit (25ml syringe and spray activator) in NZ or who will ship it internationally. I can purchase the 330 in the 250ml tube locally, but I still cant find the 7387 or 7386 activator.
Hopefully someone has some good loctite contacts?
saeco wilson will be able to get it for you, might be a special order depending where you are located.
