Honda oem connector brand
EFI Wiring Fundamentals
Hi guys, I'm looking for a little help here.
Short story is im wondering what oem brand Honda primarily used on early to mid 2000s cars
I'm building a harness from the ground up and have several spare oem Honda engine harnesses that I plan on depining and reusing connectors. I will be simplifying the stock harness dramatically for it's racecar application and routing it differently since the engine is midship mounted in a different car.
There will be all new wires run and I therefore will need new terminals for the connectors as well as mistake/expansion spares for the ecu as well as sensors.
Any help is greatly appreciated, thanks in advance!
Sumitomo and Yazaki in late '90s Hondas, havent really taken notice of any later than that.
Check with Ballengar motorsports. www.bmotorsports.com has a lot of very specific connectors you may need.
Also look at Cycle Terminals. I have used both Balenger and Cycle a couple of times over the years, and both are great. But lean more towards cycle.
Thanks guys that should be a decent start. Yea it's a lot easier to look when you know what you're looking for.
