How to pin and de-pin Series 8 FD3S ECU connector?
EFI Wiring Fundamentals
Hey guys! I have to add a few extra sensors to my JDM 2002 FD3S, and I was wondering if you guys know the part number for the pins used in this connector. I'd like to add some new pins, but alternatively I could de-pin a few unused wires (emissions and such) and just plug it in the right place on the ECU connector. Any help is much appreciated.
Part no 680-5097
Link https://uk.rs-online.com/web/p/products/6805097?cm_mmc=UK-PPC-DS3A-_-google-_-3_RS_stock_codes-_-TE+Connectivity%7CPSF_435696%7CPCB+Connector+Contacts-_-680-5097&matchtype=p&kwd-45991676723&s_kwcid=AL!7457!3!83010645403!p!!g!!680-5097&gclid=EAIaIQobChMIjv6k3NTa4QIVSLHtCh00xgAuEAAYASAAEgLqMPD_BwE&gclsrc=aw.ds
First you free them by lifting the insert one bottom of the connector with a pick or small screwdriver, it pulls out a few mm then look in the plug end and you will see a tab in the centre of each pin, lift this with a small screwdriver/pick and voila.
Thank you so much man! Much appreciated, can't wait to get started.
