i have a ignition trouble on my sr20det s14block s15 head and s13 wiring
EFI Wiring Fundamentals
Hi I have a trouble on my sr20det I don’t have spark and I all ready check every ting my question is: an sr20det s13 is it compatible for my s15 coil pack.
hello, are using s15 coils with s13 wiring ? if you are then you may still have the s13 ignitor in the loom which will need to be removed, the s15 coils have built in ignitor.
Regards Ross
Yes i have the s13 wirring but can you show me an exemple because i am not shure tu onderstand what i need to do exactlie
thank you very mucht for your supplie
Hi There!
Not sure if this is still needed. But.
I installed a S14 SR20 into my S13.
The S13 ignitor doesn't work on the S14/S15 coilpacks.
Best is to get a S14 ignitor and the 2 plugs that goes with it and wire it up to your coils/current harness.
Or better yet, try and source a complete S14/S15 engine wiring harness, as this will resolve your issues.
Here is a pretty solid guide on the swap.
https://forums.nicoclub.com/s14-sr20det-into-dohc-s13-installation-t395060.html
