Hi. I have been trying to solve a problem. My ignition coils would misfire really bad. They would overheat and damage the ecu.
I have repaired the ignition coil connectors, replaced the ignition coil condenser. I recently repaired the ground connection, and checked for continuity.
Is there something I'm missing before I install the repaired ecu?
It would help if you gave some actual information on your setup.
Coil(s) make and model, ECU make and model, coil dwell - this is usually the problem, etc.
