is there a pulse relay?
EFI Wiring Fundamentals
Hello ,
Are there any relays that operate by pulse?
I put in the mass with a push button, it closes. I reset to the mass and this time they reopen?
Thank you in advance for your answers
i am not 100 percent on what you are asking but a momentary digital input should do this in the ecu
Regards Ross
it is to order accessories from a sterring wheel panel with push buttons only
best regad's Valentin
I would just use toggling push button switches.
I'd agree to use standard relays and toggle switches but if you're in a position where you HAVE to find a solution with what you have they're usually called 'latching' relays. Hella makes/supplies a few. I'm not certain where you'd pick them up in France but here's a US amazon link to help you find something:
https://www.amazon.com/HELLA-933364027-12V-Relay/dp/B003C54BBO
Thanks for these answers, I will try to find an equivalence. It will be easier to find by starting with the exact name of the relay.
thanks a lot
Best Regards
